blockstyler radio button not sensitive
Ehaviv
Computer
Jul 2, 2003
1,012
Hi
I built a 2 radio buttons one checked by default.
when I hit an unchecked radio button
the sensitivity is good and the msgbox
in the update_cb show its message.
But when I hi a checked rsdio button
the sensitivity is bab and the msgbox
in the update_cb not triggered.
Do someone have a solution.
Thank you.
Why would you hit a 'checked' radio button and if you did, what would you expect to happen? If that option is already enabled (due to it being 'checked') hitting it again would be a 'null' action since you can't 'uncheck' a radio button. All that you can do is select different radio button since ONE of the buttons in a radio box MUST be selected. There can be NO condition where they are ALL 'unchecked'.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Hi John I`m very thank you.
In windowss I think its so.
But if that is the intended states then
I accept it.
Thank you.
