Pavan Kumar
Chemical
thread798-445071
Hi All,
I need to provide the impact force on the Impact Weir plate inside my Blow Down tank which separates the Steam Condensate and Steam. To calculate this force, I estimated the Liquid and Vapor flow rate based on the % flash and determined the velocities of liquid and gas in the 2.5" Blow down line that is connected to the vessel assuming that 50% of the pipe area for liquid and 50% for the vapor. I then calculated the stagnation pressure(Ps) for the liquid and vapor stream separately. I multiplied the stagnation pressure with the impact area ( assumed it arbitrarily to be 4" as the B/D pipe is 2.5").Then added the impact force due to liquid and vapor to give the total impact force. I wanted to check if this is right way to calculate the impact force. Attached are the Schematic drawing and the calculations in excel sheet. Your input would be very helpful to me.
Thanks and Regards,
Pavan Kumar
Hi All,
Thanks and Regards,
Pavan Kumar
