blue tooth
THEMAKER
4
Hi
i was wondering if there is any components for the blue tooth technology....i want to build something simple so i can get a better view of this intresting technology
if any info please let me know
thnx in advance
**im an electronics engineer, my first time here**
Intersil's Prism chipset (formerly Harris) is the most mature of the component solutions that are available. It is mostly being used for IEEE802.11b, but is more than well suited for Bluetooth.
The components are easy. It is the software to make it play that is the bear.
hi again
thank you for the quick response....yes i found a chip for the IEEE802.11b (LT550x family) and i was just wondering if i can use that chip...
yes the software will be difficult because its a new technology and they are still busy getting the standards correct and working out the last bit of flaws....
i will check more on this chip and see what i come up with
thnk you for the info
bye for now
THE MAKER
PS: here is the site i found this chip on if you are anyone is intrested:
