Body Feature
ianstifle
Marine/Ocean
I have a CD full of part files from Crosby that I am trying to integrate into some of my assemblies. However, they all come up as Body Features in Solid Edge. I assume that this is so no individual dimension can be changed, but is it possible to change the overall size of a part? For example, they have a general turnbuckle file, and I need to change its size in order to use it with my assembly.
Hi
You may want to use the Part Copy Command.
You can reduce or increase the part size with the 'Scale' option on the 'Part Copy Parameters' dialog box.
HTH
