Boiler size
johngladstone
133
Hi đź‘‹ gentlemen,
Is there reference book How size boiler in commercial or industrial applications ?
Thank you in advance
Best regarss
John Gladstone
I think that's called "Thermodynamics".
Perhaps a little more detail would help.
Is this for heating buildings or running a power plant or building chemical plants or what?
Hi đź‘‹ jsstephen
If we said as heating building
What code refer to ?
How can size it for working pressure heat rated etc
John,
A lot more details are needed here. A boiler isn't just something you buy off the shelf for your plant.
You need to know what pressure(s) steam is needed, total steam demand (heat exchangers, unit heaters, etc), among a thousand other things.
Yes đź‘Ť rvemeche
For this I am asking is there textbook or practical reference is available discuss about this issue I will appreciate
John,
You're getting out of your knowledge envelope here. Get a boiler wrong and it costs a lot of money or blows up. This needs proper teaching and experience. I appreciate you're trying to learn but this isn't the right way.
JohnGladstone,
Perhaps we can help you when you tell us which boiler books have you purchased and read thus far ?
Specifically, why are you asking questions about boilers ?
Have you made any effort at all to educate yourself and answer you own questions ?
Is this all idle speculation, or do you have an actual project for which you must specify a boiler system ?
In order for us to invest our time and knowledge, you must explain your status and intentions...
MJCronin
Sr. Process Engineer
