Hello everybody,
I start the flange calculation acc. to EN1591-1 and I have a doubt about the considered max allowable stress for the bolts.
I consider (values given by the software Caesar II):
- For installation and hydro-test, the max allowable stress is 485 MPa (100% yield strength)
- For service, the max allowable stress is 287 MPa (~60% yield strength)
I used to apply a torque corresponding to 75% of the yield strength of the bolt during installation (common practice).
But with this value, in most of studied cases I am out of the limits in service because 75% is > than 60%.
My conclusion is therefore: A initial torque corresponding to 75% of the yield strength of the bolt is not always relevant and in most of cases a lower torque (50% yield strength) should be better.
What do you think according to your experience?
Thank you
F67
Thank you
F67
