Mandrill22
I haven't done any calcs with gypsum before. How would I calculate the max shear that a 1/4-20 bolt (could be grade 9 steel) could take, when holding up a ss mounting plate of 9.5mm thickness? The plate will be agains 5/8 gypsum with a clearance hole for the bolt. The bolts go into rivet nuts in 1mm steel studs. The reaction forces at the plate are below.
Also, is the shear load on the rivet nut different than the reaction shear load?
