Nabil Baig
Hi there,
I calculated single shear stress in a pin as:
Diameter of Pin = 100mm
Material: IS:2062
Load / Force = 16000N
so
Shear Stress = Force/Area
=16000N/7854mm2
=2.04 N/mm2
Shear Stress =2.04 MPa
Now,
Shear Strength(Yield) of IS:2062 = Tensile Strength(Yield) x 0.58
= 410 MPa x 0.58
= 238 MPa
Now my question is, which value is to be compared with which value to ensure that the Pin will withstand the load?
Like what I see 2.04MPa is way less than 238MPa.
Please help clearing my concept.
Best regards,
Nabil Baig.
Material: IS:2062
so
=16000N/7854mm2
=2.04 N/mm2
Now,
= 410 MPa x 0.58
= 238 MPa
Best regards,
Nabil Baig.
