Bolt Shear Max Load
wagga
15
Hi All
This may sound very simple to many. Not exactly my field.
I wanted to bolt up (4 bolts) from a vertical plate to an existing beam.
Please see my attached sketch.
I intend to mount a panel on the stand which is about 80kg (including the the stand weight)
Bolt/stud is M16 grade 8.8 or equivalent.
What is the simplest calculation method to confirm that it will take the weight?
Did a check on the internet but it tend to give a complex calculation.
Appreciate the help.
 https://files.engineering.com/getfile.aspx?folder=ffb7a8bf-8eb4-4772-91c2-0336fb5cd3b7&file=Bolting.jpg
well without any calculation i would say....4 bolts M16 can take a load of 80 kg ( which is less than what I weigh )
Thanks you mate.
Just for my further understanding, which source / book do you obtain the formula.
from mechanical characteristics of material and from theory (engineering)of shear on a circular section + a safety factor (my personal understanding)
we're looking at the orange thing in the pic ? which direction is the load, horizontal or vertical ?
plus the moment of the equipment weight to the back of the plate eccentricity. In Canada, the test is (shear/allowable shear)^2+(tension/allowable tension)^2 <= 1.
Dik
Hi Gents
Load is vertically down. A panel will be bolted to a cross beam welded to the vertical stand.
