GD_P
- Apr 6, 2018
- 128
Hello forum once again,
How to select type of bolted column splice between
- Covet plate splice (require preloaded bolts for rigid connection)
- End plate splice ( do not require preloaded bolts for rigid connection)
Ref. SCI P398
FYI:
-The columns are considered continuous and support lateral load through moment connection with beam in elastic global analysis.
- The floor above the splice support rotary machine such that dynamic load ( though small in magnitude) acts along the plane of floor.
- The splices are located below the floor within 500 mm
Please share your opinion
GD_P
Ref. SCI P398
FYI:
GD_P
