RBKN
- Apr 18, 2018
- 17
I am redesigning a vertical Sec VIII Div 1 Vessel (24" OD x 48" OAH with ASME Elliptical head on both ends )
MAWP: 600psi @ 300 deg F
There is a studding outlet ( 18.75" OD x 13" ID, with 16 drill&tap holes at 16.25" BCD ) on the top head. I want to add a cover to this studding outlet using Compress. But blinds can only be added to studding outlets that have standard BCD.
My question is, is the any alternative way in which the Bolted Cover thickness can be verified using Compress? Thanks in advance
