m_struct
- Nov 11, 2020
- 64
I am looking for any guidance on bolted beam column connection for channel to tube steel post. The moment frame supporting the front end of a deck. The tube steel posts are fixed base with a post hole foundations. For constructability the beam column joint is bolted and the design only requires partial moment connection as the lateral resistance is coming from the cantilevered posts. Refer to detail below.
