macduff
- Dec 7, 2003
- 1,255
Can anyone help me with the following BOM question? This might get confusing, so I hope this comes across the right way. So here we go…………
I have a SWpart : 456-1 BEARING
I have a SWpart : 123-2 MACHINE HOUSING
I make an SW assembly:123-1 MACHINE HOUSING ASSEMBLY
(from 123,456)
I create a SW drawing from the SW assembly and insert a BOM using an Excel base BOM and my part list looks like this:
QTY ITEM PART NO DESCRIPTION MATERIAL CAGE
1 1 123-2 MACHINE HOUSING - -
1 2 456-1 BEARING - -
END……………..
Ok, now I modified that BEARING with an extrude cut (example) in the SW assembly. Now the SW assembly becomes 123-1 MACHINE HOUSING ASSY. I would like an option to show this in my BOM to look like this:
A - 123-1 MACHINE HOUSING ASSY
Is there a way to accomplish this? Can I copy specific custom properties in to an Excel template? I consider myself pretty savvy with custom properties and cannot figure this out. We do this all the time and do not want to manual modify the Excel template in each drawing. Basically, I want the SWassembly and the SWparts to show up in the BOM when I create it all the time. That would be a big help.
macduff
(from 123,456)
END……………..
macduff
