BOM
GREIF
is there a way to change the default item numbers in the bom(with out maunual typing it in). example- instead of starting with item "1" would like to change it to start with "200", "300". We are doing large
machines & for detailing we have multiple people detail different sections, so it wouild be nice on each section to not always start from "1".
thanks
1. Create new BOM Template. Hide the Item# column (this is a required column and cannot be deleted.) Insert your own custom column called something like "ItemNUM" or "Item". Do not use "Itemno" because that is the name of the original SolidWorks column. The text in the Header can say whatever you want. See more detail in the Help for "bill of materials: custom properties".
2. Add the new Custom File Property ("ItemNUM" or "Item") to every part in existing assemblies.
3. For New projects: Add the Custom File Property ("ItemNUM" or "item") to your Part Template. See help for "document template."
4. Step 2 above means you will no longer get automatic balloon numbering anymore. Balloon number is tied to the original "Itemno" column, which apperently you don’t want, because that number can often change. Instead, perform all ballooning using only custom text. That is, use split circle balloons with custom text above (where you manually type item) and custom text below (where you manually type sheet).
This method has the advantage that you have absolute control over your file property "Item" So you can maunally change your numbers if for some reason an overlap in numbers accidentally takes place between designers.
Hope this helps,
Anyone have any better ideas?????
Jon
Oh, one thing I forgot to mention is that instead of manually typing in the item numbers you can enter the first one, say "300" and use the excel functionality to drag it down the column and it should increment by 1's automaticaly. if you want higher increments you can write a formula in the cell below the first value and have it like =SUM (g1+10). then you can drag that formula down the column for as many cells as you need and it will populate the cells in that increment.
hope that helps. Regards,
Jon
jgbena@yahoo.com
