Oct 27, 2022 #1 Kami.K Materials Oct 27, 2022 2 0 0 PL Hi All, Do you know any bonding system between glass and plastic component (except glue)? Thanks
Oct 27, 2022 #2 drawoh Mechanical Oct 1, 2002 8,860 0 0 CA Kami.K, Is there a means of bonding other than glue? How permanent must this be? Must it be sealed to liquids or to air? Can you mould your plastic around a piece of glass? -- JHG Upvote 0 Downvote
Oct 27, 2022 #3 SnTMan Mechanical Jan 22, 2005 6,780 0 36 US Kami.K, there are VHB tapes. Will they work for you? No way to tell... Regards, Mike The problem with sloppy work is that the supply FAR EXCEEDS the demand Upvote 0 Downvote
Oct 27, 2022 #4 dik Structural Apr 13, 2001 25,564 0 36 CA They used to use balsam, for optical clarity issues. -----*****----- So strange to see the singularity approaching while the entire planet is rapidly turning into a hellscape. -John Coates -Dik Upvote 0 Downvote
Oct 28, 2022 #5 Tmoose Mechanical Apr 12, 2003 5,626 0 0 US I'd think the type of plastic might matter. Upvote 0 Downvote
