jplay2519
- Oct 7, 2014
- 100
I have an aluminum member that is hollow and we need to reinforce it in order for the cantilever from the base to work. The client has proposed using a 12" solid member inside the tube and just sliding it over but as we all know I need composite action in order to make that work, I can't just have them sliding over each other. I'm trying to find a way to bond these two, I'm thinking a metal epoxy but not sure for structural purposes what kind to use. I don't want to just use jb weld that I can get from walmart, want something that's used for structural purposes (jb weld may well but and I'm being ignorant but I just have never seen it in any structural conversations). If anyone has any suggestions I'd appreciate it. The base will be grouted into concrete core.
