Have you read all of the support information in the MMPDS?
I would start there.
The other thing that you need for MMPDS is to understand the statistical methods behind the values.
This varies by each different section of stress values.
The Metallic Materials Properties Development and Standardization (MMPDS) Handbook, is an accepted source for metallic material and fastener system allowables recognized by the Federal Aviation Administration (FAA), all Departments and Agencies of the Department of Defense (DoD), and the National Aeronautics and Space Administration (NASA) within the limitations of the certification requirements of the specific government agency. Some of these limitations are noted below.
MMPDS is light on material physical properties... heavy on authoritative mechanical allowables.
Both of these should be available thru well-funded technical libraries... especially companies.
Be wary... next category 'DOWN' is 'informative' data... good generalized data that informs... but may or may NOT have legal 'stature' such as 'authoritative data'... not to be used for design...
Then there is textbook data... intended for training/teaching... and general information... starter info... usually out-of-date when published.
For many alloys there are 'White papers' describing the alloys in great detail... useful and highly informative... but often preliminary and out of date.
Also, many companies publish their own materials data for locally defined/developed alloy variants under their own proprietary [company] specifications. Or publish similar-to data common alloys/industry specifications... but with notable statistical differences for their specific usage.
Regards, Wil Taylor
o Trust - But Verify!
o For those who believe, no proof is required; for those who cannot believe, no proof is possible. [variation, Stuart Chase]
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion", HBA forum]
o Only fools and charlatans know everything and understand everything." -Anton Chekhov
I'm looking for aerospace design and strength aspect.. I got suggestion to go thru MMPDS for aerospace materials.. but too informative that I'm not looking now.. I need to start with basis and will relate to aerospace parts..
Sounds like You may REALLY need to refer to an in-depth design manual/text with embedded materials data/tables for use in 'their design/analysis example/sample problems'... to get the feel for integrating materials data into stress analysis examples.
Regards, Wil Taylor
You need to use ESDU Metallic Materials Data Handbook [SI units]..
brief TOC...
Introduction
Preface
Location of relevant Data Sheets for superseded or withdrawn specifications
Conversion factors
Section 1 : Derivation and use of design data
Section 2 : Notation and definitions
Section 3 : Property relationships
Section 4 : Limitations and variations of allowable stresses
Section 5 : Standardised test procedures
Section 6 : Aluminium alloys
Section 7 : Copper alloys
Section 8 : Heat resisting alloys
Section 9 : Magnesium alloys
Section 10 : Corrosion resisting steels
Section 11 : Non-corrosion resisting steels
Section 12 : Titanium alloys
Abstract: The design engineer faces an ever-increasing demand for products with a performance that must be substantiated under stringent conditions of cost and environment. Assuming the basic skill of the designer, no other single factor can contribute more to the economic preparation of a satisfactory, competitive engineering design than ready access to good reliable design data.
Data concerning aerospace structural materials are widely scattered and, when located, are of variable quality and relevance to industrial applications. The task of collecting and evaluating all the relevant data available on a particular material property is time consuming and therefore expensive. Even if such a task is performed it is often found that the customer will wish to view the design, not against some locally derived data, but against what can be demonstrated to be the best data that can be ascertained and which are vouched for by a significant cross-section of the engineering and scientific community concerned with both derivation and application of materials data. Accordingly, this Handbook has been prepared to meet design requirements with regard to aerospace structural metallic materials properties for both the designer and his customer and, by serving the needs of many, accomplishes the task at much lower cost and with a higher reliability than could the individual.
See also MMPDS (formerly Mil-Hdbk-5).
Details: The most recent update to MMDH was to Supplement Level 50 in Jun 2023
[access will be limited to subscription customers... engineering school libraries may have it]
Regards, Wil Taylor
I don't recall the designation on the handbook behind the MMPDS. There is one that describes all of the methods, limitations, and applications.
You might need to contact Battell Columbous to find out what it is.
"behind" in what way do you mean?
In MMPDS chapter 9 is pretty detailed about methodology behind the results.
The predecessor to MMPDS is Mil-Hdbk-5 (the predecessor to that is ANC-5).
Yes Batelle is the custodian of this data now, under contract to the FAA, but it used to be the US military. They compiled the data from a wide variety of sources; some from airframe OEM's, some universities, some fastener makers, some foundries, some industry associations, etc.
I haven't looked lately but dose chapt 9 describe the statistical methods used?
There are a specific number of samples required from a minimum number of different heat lots.
Teh statistics are different for the different basis of stress.
Yes, there are some that simply based on specification minimums, but some are much more involved.
