I use lots of boolean operastions. Then one time later I take every time problem. And I lose time to find where is the problem and which body give me problem.
I am changing body's position and etc. etc.
"Hightlisgted elemnet can not be cut its tangeny contact. Modify body's contacts(use split or extrude of the body)
Is there any toolbar where is problem or a way directly show me this is problem area or inside options topology properties that I can make it more dimension?
Best regards.
Best regards.
