Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Why? Seems like added expense for minimal to no benefit.r13 said:Use two angles in X pattern.
jayrod12 said:If you need these for every beam, then yes sure, however as I understand his question, it's a single beam.
However, if it is in fact multiple beams, I'm more partial to continuous bottom chord bridging with bracing every few bays. Keeps more of the spaces open for services.
dik said:with cross-bracing in the end panels only.
