Is there a way to do this with Knowledge Fusion or something?
If your using the bounding body to measure a solid that gets features added to it after the bounding body is made, you have to manually drag it to the top of the feature tree to get accurate dims.
If you forget or make an edit to the body your measuring by accident, the BOM reporting will just be wrong.
I've got associative measurements on the bounding body itself auto reporting to the parts list thru the attribute system.
Quite a few parts in a custom library are set up this way.
It works well but this is one of the pit falls.
I don't know why this tool isn't smart like "extract body"
At least you can turn toggle "Fix at Current Time Stamp" on and off
If that could be added to it would be a lot more powerful and useful.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
Dave
NX9, Win 7 Pro SP1
