Hopefully a quick and easy question. I have a built-up box beam with thin (vertical) webs and thick (horizontal) flanges. Using AISC to analyze the MINOR AXIS moment capacity of the beam, do you flip the local buckling equations for analyzing the different elements? In other words, where AISC F7.2 provides the “Flange Local Buckling” check, should the value b/tf be changed to h/tw and vice versa for F7.3? Thanks.
