Hi.
I having an issue with using BPVC (2019) Sec VIII Div 2 Annex 3-F.
I want to use the calculations in a spreadsheet.
The number of cycles calculated does not match what I read off the graphs.
To test the forumalae, I state my Sa is 100Mpa. The charts shows ±350000 cycles (Figure 3.F1M).
I used Formula 3-F.1, 3-F.2 & 3-F.21.
I calculate 619.45 cycles.
I have used the correct temperature correction formula in table 3-F.1 for metric, used 200000 Mpa for Et, calculate a Y = 1.989.
I have double checked the formula and they are correct in the speadsheet.
Am i missing something here?
