BPVC Div 1 Bolt Load Mandatory Appendix 2.
Gavin_UK
I am trying to design a flange using Div 1, Mandatory Appendix 2 Bolted Flanges.
But because of the gaskets and bolts the flange is getting very thick, which I am trying to avoid
Most of that is driven by using the bolt load, I know using Torque to set Bolt load is quite inaccurate especially if just using a torque wrench, no washers and uncontrolled lubrication. So I presume there are some pretty significant Factors of Safety built in.
Has anyone got any experience of modifying these equations through ASME assessment for using a more controlled method of setting bolt load?
I know bolted connections are incredibly complex if you start looking in too much detail and I don’t want to go too far down that rabbit hole, but it seems to be over engineering the design currently. If anyone can offer and help or any relevant Code Cases I would really appreciate it.
Ah yes, welcome to the world of overdesigned flanges, brought to you by VIII-1, MA 2. One quick tip that may be helpful is to use a gasket with lower "m" & "y" values. In other words, ignore the "m" & "y" values shown in MA 2 for gasket types. This is done often with Kammpro type gaskets (which don't exist in MA 2), using m = 2.75 & y = 3,700 psi. I've seen calcs that will use even lower "m" & "y" values than that for Kammpro type gaskets. Lowering these gasket factors will help lower your required bolt loads on the gasket, and help lower your stresses in the flanges.
Have you kept the radial distance between the bolt circle and the gasket load reaction diameter to a minimum? And probably use more bolts (and smaller size) to keep that further closer to reduce that moment arm.
More info: design pressure / temperature, material, diameter, service,.....etc.
MA2 is for sizing the flange. Getting into actual bolt assembly stress and bolting methods will go via Appendix S into PCC-1. These are two different topics that shouldn’t be mixed up for sizing a flange, or you’ll get some heavy overdesign in there.
