Pungineer
- Aug 31, 2011
- 4
I have a question regarding precast construction with CIP diaphragm & shearwalls. The job i'm working on has precast elements, beams, columns, Double-tee's...which will be erected before the CIP shearwall & diaphragm are poured. What is the lateral system during the erection process? The columns are braced during erection, however the braces are removed once the base of the column is grouted & beams are erected. I make sure to check the columns & walls for temporary wind load after erection and size the braces and deadman appropriately, but I'm lost on the building as a whole. BTW this job is in California (high seismic).
Anyone have experience with this?
