dylansdad
- Nov 15, 2005
- 134
There are probably posts in the forum that answer this ?, but my search has been for naught.
The attached sketch shows a typical relief angle for brick veneer. The question is how is the
tension calculated for the screw bolt? Is is simply done by resolving moments about the tip
of the 5x5 angle, using a moment arm at say 1/2 the outstanding leg? Should prying be considered?
Thanks in advance.
Thanks in advance.
