I am designing a really simple one story light frame [wood] building for a place with a Seismic design category E, when I was reading the special inspections and the requirements for masonry, there was no information that prohibited me from having veneer. Then somebody kindly pointed out Section 2308.12.2 from the IBC and it reads:
2308.12.2 Concrete or masonry.
Concrete or masonry walls or masonry veneer shall not extend above the basement
Is this requirement for load bearing masonry, cause it doesn't make sense to me how it shouldn't be extended above the basement. There's also a few exceptions for SDC D regarding bracing of the veneer wall. Is there also an exception to SDC E? I read somewhere that it is possible to use if you have joint reinforcement at a max. of 18" and isolate the wall from taking any lateral seismic loads.
Could anybody share some light on this, point me to a reference to justify its use and such, I'd appreciate it.
