SleeplessEngineer
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1703094696/tips/IMG_7034_lrbkxh.heic[/url]
The penthouse wall was added with brick veneer by the architect at the last minute; we were not informed of this change. I was already not happy about this since this wall is setback from the front wall and supported by LVL beams; so, the brick veneer is supported by the wood beam.
I went to check on site and found this lintel support. Top level of door opening, and window opening is off by about 10". So, the Contractor provided two separate lintels which apparently have no support at that point. Currently a wood member is attached to support this temporarily. Any suggestion on how to support and still look not ugly?
Thank you for reading my post! I appreciate your time.
