I am working on performing some design calcs on a steel abutment cap for a bridge. Where I work, a common type of abutment is constructed of a steel beam sat on top of steel h pile. The bottom flange of the cap is welded to the steel H pile. So essentially the steel cap is laterally supported on the bottom flange with only. I am confused on what to use for the unbraced length when performing lateral torsional buckling calcs.
