We have a privately own/maintained bridge that is 15'W X 35'L. With Concrete abutments, 4-5 steel I beams spanning between the abutments and wooden decking (4X10s??).
We are working with a structural engineer and looking for a crew to do needed maintenance on the bridge. I am looking to understand what the options are so I can converse with the engineer, etc. from at least a basic understanding...
This bridge is the only access for about 8 residential houses. There are several emergency access/egress points that might be used...but normal access is only via the bridge.
The wooden bridge deck is in need of replacing and someone has suggested to the home owners assoc. that owns the bridge that we could do a concrete deck without a problem...
Anyone have any references I can access from the web, etc. Or even a library if needed. I realize this area of engineering (Art/Science) has be around since before my Grandfather was around...but it's not an area that I have done any design work. I understand the physics... more looking for things like how the bridge deck beams are secured since they can move around as the environment changes from summer to winter, etc. Also how to maintain the wooden deck beams for maximum life...
Larry
Larry Mackey
Larry
Larry Mackey
