Bringing in STP Files Journal
pittbuck
Computer
Hey everyone.
SO here's the goal: Have NX open a directory so that I can click on a folder and allow any and all STP file to be brought in to the file that I am presently working on. I have a journal for importing in STP files based on the name of the file and I have a journal that will open the a directory that will allow me to bring in STL files into it's own new part file. Below are the two respective journals. How do I need to combine these to have the STP files that I want to come in to the current? (we will sometimes have cases that either have multiple STP files or STP files with different names than what the journal presently looks for)
Pull in STL files into their own window to review:
Code:
Option Strict Off
Imports System
Imports System.IO
Imports System.Collections
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpenUI
Imports NXOpen.UF
Module Cycle_Files_and_Folders_b
    Dim theSession As Session = Session.GetSession
    Dim LW As ListingWindow = theSession.ListingWindow
    Dim workPart As Part = theSession.Parts.Work
    Dim displayPart As Part = theSession.Parts.Display
    Dim initialPart As Part = theSession.Parts.Display
    Dim nTotalStlFiles As Integer = 0
    Sub Main()
		'I am getting much of the naming info, including variable names, from the following journal:
		''Copy Crowns (Z) Folder to Dropbox'
		'That journal doesn't really get used anymore because I've moved that task to the
		'MS Access environment
		'This stuff is just to get the name of the root folder of the .prt we are currently in.
		Dim fileName As String = IO.Path.GetFileName(workPart.FullPath)
        Dim fileNameNoExt As String = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
        Dim parentFolder As String = IO.Path.GetDirectoryName(workPart.FullPath)
        Dim root As String = IO.Path.GetPathRoot(workPart.FullPath)
		Dim OrderFolderC as String
		Dim Position1 as Integer
		Dim OrderFolder as String
		Dim Position2 as Integer
		Dim OrderName as String
		'Finds last "\" in the parent folder directory path
		Position1 = InStrRev(parentfolder, "\")
		'Makes variable "OrderFolderC" contain path to the left of "\" = Cad Folder Directory
		OrderFolderC = Left(workPart.FullPath, Position1 - 1)
		'Finds last "\" in the Cad folder directory path
		Position2 = InStrRev(OrderFolderC, "\")
		'Makes variable "OrderFolder" contain path to the left of "\" = Root Order Folder Directory
		OrderFolder = Left(OrderFolderC, Position2 - 1)
		OrderName = Left(fileNameNoExt, Len(fileNameNoExt) - 6)
        Dim strOutputFolder As String
        LW.Open()
        Try
            Dim FolderBrowserDialog1 As New FolderBrowserDialog
            ' Change the .SelectedPath property to the default location
            With FolderBrowserDialog1
                ' Desktop is the root folder in the dialog.
                .RootFolder = Environment.SpecialFolder.Desktop
                ' Change the following line to default to a given path
                .SelectedPath = OrderFolder
                ' Prompt the user with a custom message.
                .Description = "Select the directory to scan"
                If .ShowDialog = DialogResult.OK Then
                    ' Display the selected folder if the user clicked on the OK button.
                    'msgbox(.SelectedPath)
                    strOutputFolder = .SelectedPath
                Else
                    'user pressed "cancel", exit the journal
                    Exit Sub
                End If
            End With
            'LW.WriteLine("Cycle All Parts in a Folder Tree")
            'LW.WriteLine("Start Time: " & CType(TimeOfDay(), String))
            'LW.WriteLine("")
			'The following code to open up the 'NEW_PART_TEMPLATE(NX8-STP)' is from 'STP Export, Review, and Import.vb'
			'   Menu: File->Open...
			Dim basePart1 As BasePart
			Dim partLoadStatus1 As PartLoadStatus
			basePart1 = theSession.Parts.OpenBaseDisplay("\\Cagenixserver\Cagenix Data\Production Support Files\WORKING PRT FILES for FRAME Design\NEW_PART_TEMPLATE(NX8-STP).prt", partLoadStatus1)
			'basePart1 = theSession.Parts.OpenBaseDisplay("G:\WORKING PRT FILES for FRAME Design\NEW_PART_TEMPLATE(NX8).prt", partLoadStatus1)
			workPart = theSession.Parts.Work
			displayPart = theSession.Parts.Display
			partLoadStatus1.Dispose()
			'   Menu: File->Save As...
			Dim partSaveStatus2 As PartSaveStatus
			partSaveStatus2 = workPart.SaveAs(OrderFolder & "\" & OrderName & "C\" & OrderName & " STL Review.prt")
			partSaveStatus2.Dispose()
            processParts(strOutputFolder, False)
            'LW.WriteLine("")
            'LW.WriteLine("Total Part Files Scanned: " & nTotalStlFiles)
            'LW.WriteLine("Stop Time: " & CType(TimeOfDay(), String))
			'This last part comes from a journal I recorded called 'After stl files imported - adjusting view'
			'   Menu: Orient View->Bottom
			'Had to add 'NXOpen' before view to get this to work, got the idea from:
			'[URL unfurl="true"]http://www.eng-tips.com/viewthread.cfm?qid=399552[/URL]
			workPart.ModelingViews.WorkView.Orient(NXOpen.View.Canned.Bottom, NXOpen.View.ScaleAdjustment.Fit)
			'   Menu: Rendering Style->Shaded with Edges
			workPart.ModelingViews.WorkView.RenderingStyle = NXOpen.View.RenderingStyleType.ShadedWithEdges
			'   Menu: File->Save
			Dim partSaveStatus3 As PartSaveStatus
			partSaveStatus3 = workPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
			partSaveStatus3.Dispose()
        Catch ex As NXException
           ' LW.WriteLine("Cycle Files and Folders Error: " & ex.Message)
            Exit Sub
        End Try
    End Sub
    'Process All Parts in a Directory
    Sub processParts(ByVal directoryPath As String, ByVal includeSubDirs As Boolean)
        Dim nStlFiles As Integer = 0
        Dim part1 As Part
        Dim files() As String
        If includeSubDirs Then
            files = Directory.GetFiles(directoryPath, "*.stl", SearchOption.AllDirectories)
        Else
            files = Directory.GetFiles(directoryPath, "*.stl", SearchOption.TopDirectoryOnly)
        End If
        For Each fileName As String In files
            nStlFiles += 1
            nTotalStlFiles += 1
            'LW.WriteLine("   " & nStlFiles & " " & Path.GetFileName(fileName))
            If (IsNothing(initialPart)) OrElse (initialPart.FullPath <> fileName) Then
                Try
                    part1 = theSession.Parts.OpenDisplay(fileName, Nothing)
                    'LW.WriteLine("open error: " & ex.Message)
                Catch ex2 As Exception
                    LW.WriteLine("exception: " & ex2.Message)
                End Try
            Else
                'LW.WriteLine("initial part equals display part: " & initialPart.Equals(displayPart).ToString)
                part1 = displayPart
            End If
            workPart = theSession.Parts.Display
            'do something
            'write your own subroutines and/or functions to process the part and call them from here
            'LW.WriteLine("    this part contains a total of " & CountBodies() & " solid and sheet bodies")
			'   Menu: File->Import->STL...
			Dim markId1 As Session.UndoMarkId
			markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
			Dim sTLImportBuilder1 As Facet.STLImportBuilder
			sTLImportBuilder1 = workPart.FacetedBodies.CreateSTLImportBuilder()
			sTLImportBuilder1.File = fileName
			sTLImportBuilder1.AngularTolerance = Facet.STLImportBuilder.AngularToleranceTypes.Fine
			sTLImportBuilder1.STLFileUnits = Facet.STLImportBuilder.STLFileUnitsTypes.Millimeters
			theSession.SetUndoMarkName(markId1, "STL Import Dialog")
			Dim markId2 As Session.UndoMarkId
			markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "STL Import")
			Dim nXObject1 As NXObject
			nXObject1 = sTLImportBuilder1.Commit()
			theSession.DeleteUndoMark(markId2, Nothing)
			'theSession.SetUndoMarkName(markId1, "STL Import")
			sTLImportBuilder1.Destroy()
            'close file unless this file was initially open
            'If (IsNothing(initialPart)) OrElse (initialPart.FullPath <> fileName) Then
              '  part1.Close(BasePart.CloseWholeTree.True, BasePart.CloseModified.UseResponses, Nothing)
              '  part1 = Nothing
              '  workPart = Nothing
               ' displayPart = Nothing
            'End If
            REM If Not IsNothing(initialPart) Then
                REM Dim partLoadStatus1 As PartLoadStatus
                REM Dim status1 As PartCollection.SdpsStatus
                REM status1 = theSession.Parts.SetDisplay(initialPart, False, False, partLoadStatus1)
                REM displayPart = theSession.Parts.Display
                REM partLoadStatus1.Dispose()
                REM theSession.Parts.SetWork(displayPart)
                REM workPart = theSession.Parts.Work
            REM End If
        Next fileName
    End Sub
    Function CountBodies() As Integer
        Dim total As Integer
        total = workPart.Bodies.ToArray.Length
        Return total
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
'Below are common functions I've used in the past and copied from another journal
Function GetFileName()
	Dim strPath as String
	Dim strPart as String
	Dim pos as Integer
	'get the full file path
	strPath = displayPart.fullpath
	'get the part file name
	pos = InStrRev(strPath, "\")
	strPart = Mid(strPath, pos + 1)
	strPath = Left(strPath, pos)
	'strip off the ".prt" extension
	strPart = Left(strPart, Len(strPart) - 4)
	GetFileName = strPart
End Function
Function GetFilePath()
	Dim pos as Integer
	Dim pos2 as Integer
	strPath = Left(strPath, pos - 1)
	'pos2 = InStrRev(strPath, "\")
	'strPath = Left(strPath, pos2)
	GetFilePath = strPath
End Function
Function GetFileName2()
	Dim strPath2 as String
	Dim strPart2 as String
	Dim pos as Integer
	strPath2 = displayPart.fullpath
	pos = InStrRev(strPath2, "\")
	strPart2 = Mid(strPath2, pos + 1)
	strPath2 = Left(strPath2, pos)
	strPart2 = Left(strPart2, Len(strPart2) - 15)
	GetFileName2 = strPart2
End Function
End Module
Sorry for the weird spacing here. Literally just did a COPY-PASTE and it looked like this. This is the IMPORT STP files. I'll go ahead and let you guys know that the necessary DIM stuff is in this journal, but WAAAYYY before this part.
Code:
			'   Menu: File->Import->STEP214...
			'Following code is used to get the current file name and path for approval file
			'Dim currentPath as string
			' Dim currentFile as string
			 'currentFile = GetFilePath() & GetFileName() & ".prt"
			 currentPath = GetFilePath()
			 currentFile = GetFileName()
			Dim step214Importer1 As Step214Importer
			step214Importer1 = theSession.DexManager.CreateStep214Importer()
			step214Importer1.SimplifyGeometry = True
			step214Importer1.LayerDefault = 1
			step214Importer1.InputFile = CurrentPath & "\" & CurrentFile & " DWUCB.stp:"
			step214Importer1.SettingsFile = "C:\Program Files (x86)\Siemens\NX 8.0\step214ug\step214ug.def"
			step214Importer1.ObjectTypes.Curves = True
			step214Importer1.ObjectTypes.Surfaces = True
			step214Importer1.ObjectTypes.Solids = True
			step214Importer1.InputFile = ""
			theSession.SetUndoMarkName(markId1, "Import from STEP214 Options Dialog")
			step214Importer1.SewSurfaces = True
			step214Importer1.OutputFile = CurrentPath & "\" & CurrentFile & " DWUCB.stp:"
			markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Import from STEP214 Options")
			step214Importer1.FileOpenFlag = False
			nXObject1 = step214Importer1.Commit()
			theSession.SetUndoMarkName(markId1, "Import from STEP214 Options")
			step214Importer1.Destroy()
			'Following code makes STP Bodies on layer 1 medium purple and translucent
			'Declaring variables for recoloring bodies on layer 1
			Dim allObjects as NXObject()
			Dim ColorObject as Body
			allObjects = workPart.Layers.GetAllObjectsOnLayer(1)
			for each someObject as NXObject in allObjects
				if someObject.GetType.ToString = "NXOpen.Body" then
					ColorObject = someObject
					ColorObject.Color = 127
					ColorObject.RedisplayObject
					end if
			next
			'Moving Objects from layer 1 to 100
			'Declaring variables for moving objects to 100
			Dim MoveObjects as NXObject()
			Dim myMoveBodies as DisplayableObject()
			Dim i as integer = 0
			'displayModification for Moving objects
			Dim displayModification1 As DisplayModification
			displayModification1 = theSession.DisplayManager.NewDisplayModification()
			MoveObjects = workPart.Layers.GetAllObjectsOnLayer(1)
			for each someObject as NXObject in MoveObjects
					redim preserve myMoveBodies(i)
					myMoveBodies(i) = someObject
					i += 1
				end if
			next
			With displayModification1
				'move layers with a display modification
				.NewLayer = 180
				.Apply(myMoveBodies)
				.Dispose
			End With
end sub
	Dim pos as Integer
End Function
	Dim pos as Integer
	Dim pos2 as Integer
End Function
