Broken Dims
djmjr
Aerospace
Feb 7, 2014
22
Is there not a way to show the "zig-zag" on a dimension line for a broken dim?
I want to add the blue zig-zag and remove the part of the dimension line between pts A and B.
Thanks!!
I don't think you can do that with CATIA, unless you do it to a Radius dimension.
You can clip a dimension line, but that removes one side or another. And you can interrupt extension lines, but not the dimension line.
You can break a view, but the dimension lines will not be broken.
I've never seen dimensions broken like that - which drafting standard permits that?
