We have a 100 KVA three phase brushless alternator in our shop for repair. One of the diodes on the rotating ring needs to be replaced. The diodes have no identification markings on them-either worn off or never existed. The excitation voltage is 46 volts, and 2 amps current. Would a 50 volt, 15 amp diode be a suitable replacement, or do I need to upsize? The diode is stud mounted to the heatsink with a M6 thread.
