BS8888 and Hatch Patterns
physicshack
Industrial
Mar 30, 2018
8
NL
Hello
I have a question on sectional arrangements and hatching. Drawing mechanical components, in a section view what is the standard for hatching in BS8888. The reason I ask is that we are sectioning a part in aluminum and the listed hatch pattern is ANSI38. This is essentially a cross hatch pattern with broken and staggered lines in one of the directions. When applied to the drawing view it make the lines look a little unclear, so I am keen to check on what is the standard when working to BS8888. I would like to stick to the standards where possible. Usually the materials are steel or iron, which are a much planer hatch in continuous lines and so don't have negative impact on the clarity of the details.
Appreciate any guidance from the community. clipping attached.
Kind regards
David
 https://files.engineering.com/getfile.aspx?folder=fdb3c69d-87e4-4443-9f1d-1d713006f1b1&file=Hatch_Sample.JPG
Generally your job is to create drawing that is legible, so if hatch pattern is getting in the way, drop it.
Unfortunately I cannot provide reference to standard number, but if memory serves, general-purpose hatch can substitute material-related one.
Maybe this could put you at ease (courtesy of Genium Publishing):
