BSP threads?? 1
rossob
70
I have noticed no BSP thread forms are available. We have quite a lot of items that require BSP fittings. What do people use instead of BSP?? Or is there something downloadable to remedy this?
Ross
NX5.0.2.2 WinXP SP2
SolidWorks 2007
We type in the value ID/OD TPI etc to suit. As they're only used on certain fittings we seldom have to repeat the exercise.
Best Regards
Hudson
I insert folowing data to thd_metric.dat file (hd_english). I dont know how threads works in NX5
BSP,0,55
# British Standard Pipe Thread
# Data from Maryland Metrics #----------------------------------------------------------------------------
# Name Major Minor Pitch Tap Drill Shaft Depth
# Dia. Dia. Dia. Dia.
# (internal (external (75% full
# threads) threads) thread)
# (mm) (mm) (mm) (mm) (mm) (mm)
1/8_BSP 9.728 8.566 0.907 8.700 9.728 12.000
1/4_BSP 13.157 11.445 1.337 11.600 13.157 16.000
3/8_BSP 16.662 14.950 1.337 15.000 16.662 18.000
1/2_BSP 20.955 18.631 1.814 19.000 20.955 20.000
5/8_BSP 22.911 20.587 1.814 20.750 22.911 21.000
3/4_BSP 26.441 24.117 1.814 24.500 26.441 22.000
7/8_BSP 30.201 27.877 1.814 28.000 30.201 23.000
1_BSP 33.249 30.291 2.309 30.500 33.249 24.000
1_1/8_BSP 37.897 34.939 2.309 35.000 37.897 25.000
1_1/4_BSP 41.910 38.952 2.309 39.500 41.910 26.000
1_3/8_BSP 44.323 41.365 2.309 41.500 44.323 27.000
1_1/2_BSP 47.803 44.845 2.309 45.000 47.803 28.000
1_3/4_BSP 53.746 50.788 2.309 51.000 53.746 30.000
2_BSP 59.614 56.656 2.309 57.000 59.614 32.000
2_1/4_BSP 65.710 62.752 2.309 63.000 65.710 33.000
2_1/2_BSP 75.184 72.226 2.309 72.500 75.184 34.000
2_3/4_BSP 81.534 78.576 2.309 79.000 81.534 35.000
3_BSP 87.884 84.926 2.309 85.500 87.884 36.000
3_1/4_BSP 93.980 91.022 2.309 91.000 93.980 37.000
3_1/2_BSP 100.330 97.372 2.309 97.750 100.330 38.000
3_3/4_BSP 106.680 103.722 2.309 104.000 106.680 39.000
4_BSP 113.030 110.072 2.309 110.500 113.030 40.000
4_1/2_BSP 125.730 122.772 2.309 123.000 125.730 42.000
5_BSP 138.430 135.472 2.309 136.000 138.430 44.000
5_1/2_BSP 151.130 148.172 2.309 148.500 151.130 46.000
6_BSP 163.830 160.872 2.309 161.500 163.830 48.000
Thanks for that, it worked well. Another question I have is relating to hole callouts. Please forgive my ignorance, as I am a new user.... If i want to see a hole callout i add one by using the feature parameters command. This however, gives me nothing even close to what the hole callout is designated in the "NX502_THREADED_HOLE_STANDARD.XML" file.
Am i doing this wrong, or is there a better way to do this??
Ross
NX5.0.2.2 WinXP SP2
SolidWorks 2007
