So I have these fittings that are said to be G1/4 threads which are BSPP straight threads. The original female fittings inside have a copper crush washer that bottom out on a flat backing that seal against the male and female connections. I bought new female fittings to replace them that are also BSPP straight threads but they do not have these same copper crush washers and they are not flat inside like a flat washer could have been inside, they bottom out on a taper/cone/angle cut. This new fitting does thread all the way down 10+ threads so the threads are correct.
My question is, is there more than 1 kind of BSPP thread that does not have this crush washer? If yes are the 2 types compatible if threaded all the way down until they bottom out?
thread explaination
thread explaination
