SteveGregory
- Jul 18, 2006
- 554
This would apply particularly for spreader beams. Is the allowable bending stress in Section 3-2.3 based on using the plastic section modulus or the elastic section modulus?
The text only refers to these two properties, Sx and Zx in terms of the unbraced length. In my case, there is a tube section being bent in the weak axis. If I were using AISC 360-10, it would be Eq F7-1 with the plastic section modulus Z.
However, the ASME BTH-1 2014 equations look more like the ASD 9th Ed. We used the elastic section modulus for these allowable stresses.
