BTU equation
CMurry
13
Can someone refresh my mind with the equation to calculate Btu's to Tons CO2? Thanks CM
Depending what you're oxidating, I think
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying ” Damn that was fun!” - Unknown>>
Oh, and how good the oxidation is. Am I totally wrong here? But you cannot convert BTU's to tonnes of CO2. You could estimate how many tonnes of CO2 you'll get from burning a particular fuel which, in return will give out so many BTU's.
Or are you looking for the conversion factor similar to normal air conditioning?
TTFN
FAQ731-376
A BTU is a measure of heat and a ton is measure of weight or mass (depending on what you are measuring and how). I am not aware of a similar equation to change an apple to an orange.
Don Phillips
1 ton A/C is about 12,000 BTU/hr
TTFN
FAQ731-376
IRstuff, is that a convention? Would you know how this was determined? I am sure I'll face this in the near future and would like to look less ignorant than I am
Of course, natural gas to power to cooling. Thanks
Table 3 of the linked doc says:
1 Million Btu's = 55kg CO2 (121 lb)
I think this is what you are looking for. The equivalence of Btu's in CO2. This is a calculation that works back through the chain of usage, conversion, transmission, generation and I guess is done on national averages for each (I didn't read the whole document!).
