Dear experts,
This query is based on simulation results (aspen hysys).
What I thought was scrubber or column bottom pressure would be at bubble point which corresponds to bubble point pressure. However, the vapor pressure at the scrubber bottom temperature (with the same composition) is estimated to be higher than the column bottom pressure. How can I explain this situation?
For example, the scrubber bottom pressure is 1.028 bar at temperature 45.82oC. Bubble point pressure is estimated at pressure=1.05 though temperature and composition are kept constant.
