Buckling Load
Mateus_R
48
Dear all,
I have to evaluate the effect of the buckling in a bar, and some questions arise, specially regarding the ANSYS Mechanical interpretation:
Suppose I evaluate buckling according to image attached, case 1 -> Ansys will give me the critical buckling load related to the applied load, by means of the loading factor, and this is straightforward.
Suppose case II - now I have two compression forces located at different points. Ansys still gives me the loading factor, but in this case how can I interpret it? How the loading factor is related to each of the two forces?
Thank you for the support.
If this is not prestressed buckling then at second case buckling occur when F1 F2 and F3 multiplied by load factor, it is obvious.
