  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Buckling using ASET method in Femap
nuraen
3
0
0
Need help setting up Buckling using ASET method in Femap.
I got a FATAL after an attempt at running a model.
I ran a static model, modified the .DAT file for buckling, added statsubs and method to all the subcases; added the EIGRL card, created a new constraint group (fixing all 6dofs) and used the group to create ASET bdf. Is fixing the 6dof appropriate? If yes, what could be source of the singularity FATAL I am getting?
ASET GRIDs should have all 6DOF constrained. You also need to include an SPC in addition to the ASET. See below for an example case control:
SUBCASE 1
SUBTITLE = STATIC_RUN​
SPC = 1​
LOAD = 1​
SUBCASE 2
SUBTITLE = BUCKLING​
SPC = 1​
STATSUB = 1 (static subcase)​
METHOD = 1 (EIGRL METHOD ID)​
BEGIN BULK
ASET 1 123456
ASET 2 123456
ASET 3 123456
ASET 4 123456
