EnginerdNate
Aerospace
- Feb 4, 2019
- 84
Hi all,
Aero guy here doing some basic work on a beam for a personal project, wondering if anyone here can help me out. Pics attached show the beam dimensions and configuration, along with some napkin math. This was done to learn a bit more about wood construction as much as anything. I realize a TJI or gluelam would be easier to size for a real structure. That out of the way.
I built the box with SYP for caps and 22/32 OSB for the webs. Glued and screwed with PL Premium and Fastenmaster HeadLok fasteners on a 7" pattern, staggered on each side so the fasteners don't fight in the center of the cap.
I found strength values for SYP here:
My original napkin math assumed higher allowable stress than what's in that table (I was seeing strength values for SYP in the low 3000-4500psi range and MoR over 10k psi on less official sites before I found this resource) but I applied F.S.=5 to those initial calcs.
Using the values from that table with F.S.=5, I clearly need to limit load to much less than the 1000lb I've used to do the initial calculations. Are these intended to be "allowable" loads that you just have to stay below, or would a safety factor typically be applied on top of these values?
Any resources for fastener bearing strength in OSB and SYP, and panel shear strength of OSB would be helpful as well.
I'm already considering doubling the fastener count to 3.5" spacing just based on gut feel on fastener load in the OSB. The bond should be plenty to take the entire shear load but I don't trust it as much as a fastened joint so I'd planned on belt and suspenders.
Nathan
Nathan
