Have received an assembly of multiple panels which are joined by rivets. The solid model contains rivet holes numbering in hundreds. I have to extract outer surface and fill up the holes to get a water tight geometry. Very hard to do fill individually for each hole. I did explore in GSD and was not able to find an option to do like a batch fill for numerous boundaries/outer curves.
Just wanted to post here and see if a tool/function like the above exists in Catia V5.
Thanks...
Thanks...
