I'm reviewing drawings prepared by another engineer and he has 6" wide beams with two 2 -3/4 inch bars top and bottom. Because the structure is close to the sea, the concrete cover is 1.5" which doesn't leave any space between the bars. I raised this with the design engineer and he indicated that the two bars are bundled bars so he need not satisfy the spacing requirements of ACI Cl7.6.
I've never seen a 6" wide beam before much less two bundled bars in the bottom and two in the top with a ties around them. Any thoughts or comments?
