Bunker Oil C
leia01
Chemical
Mar 9, 2017
1
Hi! I need to have a data for the properties of bunker oil C for the design of shell and tube heat exchanger. Heat capacity, thermal conductivity, density, and viscosity. If possible, I would like to know the value of theses properties for the temperature range of 80°F to 580°F. Thank you
Hello everybody:
You can start your search by reading the thread481-133221.
El que no puede andar, se sienta.
