Titleist.Guy
- Jan 1, 2019
- 6
Hi all and Happy New year!
So, I came into today and walked through the site, and found quite a bit of this, (see attached photo).
The problems here are pretty obvious:
1) Non-engineered web openings
2) Torch cutting these holes
My question, to the best of anyone's knowledge does the AISC DG#2 extend to any other shape besides W flange? I'm assuming it does not. Intuition tells me that with the shear center being off the shape already, and now removing the middle(ish) portions of the members, that we're going to see a different response in the member due to the openings. The problem is, I can't find any literature on web-openings for channels. I've gone through the Modern Steel steel-exchange archives, scoured the net, and re-read the AISC DG#2. The closest I'm finding is a very little info on cold formed steel shapes. I'm looking for any advice or wisdom that anyone wants to share before I go lay into the contractor, and their engineer.
The loads are reasonably light -- however, if we use the DG#2 as a benchmark, then I think we're in a bit of trouble:
I know that several of these shapes are likely not compact,
In several locations the point loads are dead nuts over top of the opening, which wouldn't even fly if it were w-shaped members,
Also, many of the geometric recommendations in AISC DG2 wouldn't even apply here, with respect to opening ratio limits, and hole sizes,
The holes that were burnt suffer from 'beaver chewing', with many edges longer than 3/16" b/c no one ever went back to grind those smooth,
And if we wanted to add some 'token' reinforcement, there wouldn't even be enough available section left to attach to.
Now, not all the holes are created equal, some are much smaller, not pictured, and are possibly reinforce able, but this goes back to my original question, I can't find any reasonable guides in the literature. Part of me thinks putting 'back' the amount of section that was removed via bars or cut pipes welded around the holes might just be the solution, but I frankly don't know.
Anyway, I appreciate anyone who took the time to read this and any insight would be great.
Thanks!
Thanks!
