So I am doing a solidworks simulation on a copper tube with brazed flat endcaps. I applied an internal pressure of 350 psi, and an internal and external temperature of about 80 degrees C. The tubing is 1"OD X .05" Wall, and for the simulation the length is 11". The yield strength of the copper is around 260 MPA. The tubing appears to exceed yield strength around 350, but appears to be ok at 320psi. Now the thing is when I go online to just look up burst pressure of copper tubing I apply barlows formula and i am getting a bursting pressure of 35psi. So now I am confused as to what this tube can handle. I have also found a copper ratings chart which shows 1" tube with .05" wall saying that the working pressure is 420psi.
