No.
Read what he said, don't read more into it than exactly what he said.
Bus has a current rating. So a 2000A bus is rated 2000A at 1V, or 480V, 0r 4160V
Voltage on the bus has only to do with the spacing and / or insulation rating, hence a maximum voltage rating as he said. That just means that if you have a bus system designed to be used in 4160V gear it will likely be 5kV rated bus, you cannot use it for 15kV gear. But you can use it at 3300V or 2400V or 1500V, anything lower.
That still has nothing to do with the current rating. It's still 2000A no matter what.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> faq731-376
