CloudNine1
Hi guys,
I would like to calculate the thickness (and the other parameters needed) of butt weld that connects between a pipe and a weld neck flange:
I couldn't find any thumb rule, or even better: an analytic formula (which involves working pressure, temperature, etc) that allows calculating the required sizes for the welding.
I also need such formula for fillet weldings.
Thanks.
Thanks.
