BlakeG
- May 31, 2019
- 1
We have a job coming up consisting of welding hastelloy C276 material. Mostly this will be welding support beams 3/4" material to 1" material welded with fillets. In another part of the job we will have to weld a 2" thick support ring to a 1/4" plate using a 1/4" fillet weld. All of this will be done in the flat position using GTAW and GMAW processes. Can you tell me what the plate size requirement is for this PQR? Also, for the welder qualification, is it necessary to use C-276 as the base material? I believe it is for the PQR, but not sure about the welder's test.
Blake
Blake
