Sam Low
- Oct 30, 2019
- 31
Hi All,
There is a 600 N/m distribution load applied to the same size of channel but in different configuration. Herewith attached the sketch for your reference. Which configuration is better?
In my opinion, it will be more or less the same since the contact area (Highlighted in yellow colour) is almost the same.
Hope you all can help me out on this.
Thank you!
Thank you!
